Hickory-NC-2Ggsx
Supporting VIP
- 312
- 137
- Dec 27, 2018
Lincolnton,
North Carolina
HI everyone! Alright so i just wanted a second opinion on these specs that i came up with so far. And everything seems to be okay so far. The motor is just a stock rebuild with .020 pistons, arp headstuds and a balance shaft delete. But heres what I've gotten done so far.
-Main journal oil clearance is .020mm
-End play is .06mm
-Rods will be next week hopefully.
-Piston rings
1st ring .32mm
2nd ring .28mm
Oil ring .26mm
-Oil pump drive gear .12mm
-Oil pump driven gear .08mm
I wil say im surprised how well the oil pump is with 21200miles on it as far as im aware of.
-End play is .06mm
-Piston rings
1st ring .32mm
2nd ring .28mm
Oil ring .26mm
