650's or 680's?
Knuckles2.0
101
May 6, 2003
McChord, Washington
so its bigger injector time, i'm going with either fic 650's or extremepsi's 680's.... ups and down to either... i'm not sure what turbo to go with yet either a evo16g or a pte50.. so info please
If you go with a 16G then 650's will be fine but if you with a 50 trim then 720's will be better.
I had 660 ball/disc on my L2R and 50-trim and they were fine for 20psi.
650's for a 16g? christ. anyone remember 5 years ago when 550's were rediclous for a 20g?
650's for a 16g, wow.
What makes their brand injector different than an FIC injector anyway? The pictures on thier website shoing thier own injector are all from FIC's website anyways so what gives?
Dont get injectors from extremepsi. I have them and they turned out ok in the end. But my first order, one of them did not fit, and so I had to send all 4 back and wait 2 weeks for a new set. Get some injectors from a different place. Extreme PSI is cheap, but you get what you pay for.
Go with 650cc minimum. I have FIC 650's and am happy with them. 550's are NOT worth it from my experience.
You think that's bad, for a little while I had 780's on my Big 16G OMG , but I knew I was going to a bigger turbo. However, I am now considering 660s or 720s.
I have FIC 650 and they fit good and eliminate the factory hard seals.
Also 650 flow more or any injector as you raise fuel pressure so all a person might need is an afpr and good pump and 650s rather than 720s with no afpr.Just a thought guys.
