6-disc cd changer wire
grmoo
95
Aug 10, 2002
Portland, Maine
Where does the 6-disc changer wire come out in the back of the car? I cannot find anything anywhere...
Look under the trim panel over the wheel housing, and in the hatch for the taillight bulbs. First, pull up your door tread and look for it under there, along side the other wires. It'll be a dark grey wire about ¼" diameter. I wonder if you may not have one on an N/T.
Well, the radio that WAS in it which was the stock one has all the CD stuff on it...it also has the cable under the passenger side seat where the amp is supposed to be, and in the back you can see where there is wear from where the CD changer was at one point.
Right, well...I was looking everywhere I pretty much tore the car apart to find it and behind the back seat I found like a cut in the cloth like where a wire would ahve gone so I took the seat off and I didn't find any wire or any place where the wire would go! So apparently the wire was taken out or something which wouldn't surprise me and I am sure that they are probably like 200$ a piece.
