6 Bolt Swap Tool
pahel9581
Mar 12, 2003
Im currently in the process of doing alot of engine swaps... Here goes the scenario I originally owned a 1990 GSX that has been sitting for a yr that has a standard rebuild motor and a 1997 GST with a built six bolt from slowboy racing. I still owe 7 grand on the GST so I bought a 1996 TSI AWD with a blown motor for a couple grand. Im looking to put the built six bolt in to the TSI so I need a replacement for the GST which Im thinking the six bolt on of the GSX would be perfect for. Just so I can sell the GST! Now I need to know to make the swap what is the specific tool I need that doesnt work when making a regular engine swap... is it the tensioner arm tool? and is there anything else I need. Will the lower compression show a sign of poor performance once put it? Fellower DSMers anyone have a clue?
It's actually a rather simple swap. I would say just as simple if not a little easier than the myriad of "Lego-esque" Honda swaps out there. It's pretty stright foward with a few details that if you do your research before hand shouldn't catch you off guard.
Tools needed are the basic set of tools needed to do a good tune-up and replacement of the essentials like, timing belt, water pump, seals and gaskets.
Compression is lower on the 6 bolt but you wouldn't tell if unless you did a compression test. To my highly sensitive buttocks, they feel the same.
yeh im trying to get it taken care off that way I can get my AWD rollin and get rid of a high finance payment....Ill be cruisin by summer hopefully!
I have some big plans for it including a Forced Performance turbo....ForrestoR Intake Mani and AEM EMS to go along with a stage 3 slowboy built engine with a set 272's and alot of head work thats in my GST thats going in the AWD! Could always use help....sometimes two is better than one
i thought the compression was higher on the 6 bolt since the pistons are 9:1 and and the 2g were lower . i still have my 2g rods and pistons left cuz i couldnt afford to get the 1g rods machined to fit them.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
