6 bolt swap timing covers
You can use the 7 bolt covers for the swap but you'll need to use the backing plates from your 7 bolt as well. No matter what cover you use, you'll have to do some trimming and there will be at least one bolt hole that won't line up with the cover holes. The main area requiring trimming will be the water pump area; a little time with a Dremel tool or belt sander works wonders! I prefer the multi-piece cover, anyway. It looks clean longer and is lees of a pain to remove in the car. ;)
