550's in...but a leak?
TurboB5
190
May 22, 2005
rt. 78/22 (908), New Jersey
Today i got around to putting in my 550's, but after the install there is a leak coming out of the injector nearest to the driver side.
All the others seem to be sealed fine with no leak, but there is a small leak from that one. Excuse my description, but I think its the black rubber gasket/rubber piece that sits on the bottom of the injector. All 4 o-rings were in fine shape, so i dont think thats the problem, or even if it could from where the gas seems to be comign from.
TIA:talon:
i recently put 550s in also that were leaking everywhere. i put new o-rings on it still leaked...finally i doubled up on the o-rings and it has not leaked since. do not go to an auto parts store and buy an injector o-ring kit though(they rape you). just take one of the o-rings and have them match 4 more up. the problem was not the lower one, it was the upper one, and it kept getting cocked sideways a bit. good luck man, hope you have an afc or something, if not then i would put the 450s back in.
I do have an AFC.
The orings seemed fine, but when i put on the spacer, it did seem cracked a little on the bottom. Ill do an O ring and spacer just to be safe, thanks guys
