2G 4g64 rebuild
StanleyDSM
248
6
Jun 30, 2015
Cherryville, North Carolina
So I'm rebuilding my 4g64 sohc. Pretty much just putting new bearings and new rings on the pistons. Is there anything I need to do to the cylinder bores while I'm in there or anything?
U will want to at least de-glaze the bore with a bottle hone, id recommend a stone hone and good cleaning for good measure. Plus the stone hone will show you more of the taper and/or imperfections in the bore.
Depending on how far you're planning on taking the block, could clean up the oil passages and do all those simple mods for fun/insurance.
Past that, keep it clean.
just hone the cylinders and blue print it. have crank, rods, pistons and flywheel balanced then you can delete the balance shafts. if you want better efficiency you can put the 4g63 head on. but 5 holes will need to be covered. or as is would be cheaper. NPR makes great oem replacement pistons.
U can use the "dingle-berry" bottle hone, it conforms to all the surfaces so it'll prolly look cleaner, or you can use the triple flat stone type that's spring loaded. It will give u more uniform honing, but u might notice the point of cylinder taper at the top of the bore with it, as it won't reach into crevices. This would tell you how bad the taper is and if you should have it professionally honed or bored.
You can purchase either hone at most chain auto parts stores, just know the rough size of the bore to get the proper size hone (s).
If you've never done a home honing job, I suggest watching a couple vids on YouTube first, there's a technique to each one. You'll want a drill that at least can do ~2500 rpm and some oil for lube.
You have to be more careful with the stone hone, as it can score the cylinders vertically if you pull it in and out without compressing the springs. You'll see proper use in the videos.
Lol I was getting ready to ask about the dingle berry hone. That's what I was doing last night was looking at YouTube vids of how to do it. It seems pretty simple, how intense should I clean it after I hone it?
