4G64 Hybrid HP Gain???
Originally posted by A. Van
Are you guys using the Magnus 2.4L or are you building a 2.4L from the galant...or using a Hyundai 2.4L block, which from what I was told is pretty much the same as a 6-bolt 2L.
It doesn't matter who you purchase from or if you build it yourself the block will source from various models of Mitsu or Hyundai vehicles. Magnus doesn't have a special block.
Sorry for hijacking the threard Please feel free to PM me a reply, if you wish
Can you take a stock hyundai block, slap 6-bolt heads and stuff on it and go...with fuel and computer upgrade of course
The 6 bolt 2.4's have pretty much a flat top piston, with the exception of two small valve reliefs for the original 2 valve SOHC head. If you use the original pistons you will end up with a compression ratio around 11 or 12.0to1. The later 7 bolt 2.4's you can use the original pistons and end up with around 9.5to1.
So yes, you will need to change the pistons on the 6 bolt 2.4 to run any kind of boost without getting knock, or run C-16 all time.
The 63 head bolts right onto the 64, They say you can run the stock 63 head gasket if the 64 has the stock bore. I run the cometic head gasket from Magnus with no problems.
Just to let you guys know, I have two running 2.4's, one in my race car, and one in the daily driver. The daily has 3in turbo back and a small 16G. I have the boost as low as it will go (10 lbs) and my injector DC is at 122% and I'm getting 18 counts of knock. I thought the 450's would handle at little more than 10 lbs of boost, I thought wrong. This car ran 13.40's with the 2.0 with a 14b at 16 lbs. Yes its funner (torque) to drive with the 2.4. It feels alittle faster than the 63, But I bet if I could run 16lbs it would screem. I guess I'll get some 650's for it.
Hey hose10172, I would have .82 ex housing, But I just don't know if I will be replacing this turbo with something else in the near future. I'm sure the .63 housing is choking some Hp. Plus the spool up time difference between the .63 & .82 is only like 300 to 400 on the 63, Prolly less on the 64.
:thumb:
some galant GS models came with DOHC 4g64 motors (93-96 models i think). my question is, does the dohc 4g64 head ports match that of the 1G or 2G 4g63s i.e. the intake and exhaust manifolds bolt on? how bout the cams? i know theyre aren't identical, but who knows.
dont you have to plug some oil vents on the 64 block to bolt a 63 head on?
You are talking about the 94 Galant GS(which if you look I have). It came with a DOHC 2g head, a 60mm TB and I'm not sure if it is a 1g or 2g style intake manifold. The head is the same mitsu part # as a 2g. From looking at the cams, they are at least close to a 2g, but I'm not forsure on that.
Hope that helps
Yes!-If you want you can drill a few water holes in the deck to match 63 gasket and you have to drill/tap bosse on block for knock sensor.
Would it be less exspensive to get a shortblock from magnus, or building one yourself considering that you do none of the maching work. and you use the same internals. I want to build a 4g64 or buy one from magnus. And also would i need the 4g64 block or the g64b block to put in a 1g.
p.s. i want a 6 bolt and i want to bolt my DOHC head on it also
Thanks,
-KY
The Magnus block might not be cheaper BUT it would be 10x easier to just call him and have him ship out a block. That way you don’t have to go to a junkyard and pull a motor. Don’t have to find a machine shop you can trust etc.
Thanks ^^^
But if i were to build my own dont the 1'gers have to get a differnt block?
and any of you kjnow how much it would cost to fully port and polish heads with new valves and spring snd shizz? just a guesstimate?
Thanks,
-KY
