1G 4G63 non turbo with bad miss at 3200-4000 rpm
zkheasley
69
13
Jan 25, 2014
marietta, Ohio
I have a 91 eclipse and since the day I bought the car its always had a miss. I've searched every forum on here and can't find anything for this. The motor cuts out like its hitting the rev limiter at 3200 rpm's and around 4000 it takes off and runs perfect. I used this car strictly for racing so I usually can keep the rpm's up there with no issues but restarts sure suck. Parts I've changed so far that didn't help are coil packs, ignition module, plugs and wires, cams, ecu, tps, maf, head and gasket, intake gasket, injectors,fuel rail, fuel pump, fuel pressure regulator. If you know of a post that may help me out or have any advise I wanna here it.
