420A 4G63 Fan in 420a
estuardowrld
128
17
Jun 11, 2023
Southgate, California
Hello this might be a stupid question but would it be possible to wire some 4G63 Fans onto a 420a?
For reference this is the fan i want to wire/install.
Those don't seem to be 4g63 specific. Most radiator fans are a 2 wire setup, which is almost universally compatible. That fan shroud though... what the hell are the lower holes supposed to mount to...
I’m thinking of writing a detailed tutorial on how to run a Turbo radiator for the 420a guys. Also i managed todo it with working A/C.
Yeah i ended up using the fitting like he said. The big issue i ran in with was getting a hose to connect to the lower radiator hose. But since i got people at a part store i get the privilege to test almost all the hoses to see which work the best 😉
Are there any other options of fan out there?
Did you use the Neon plastic water pipe?
Also I'm not sure if that fan shroud will bolt to the radiator. I just know the fans could be wired in.
I ended up spending 60$ On hoses and 200$ on the radiator. I have the part number and i want to do a write up so us 420a guys can beef up our radiators. It honestly is really easy if you have a A/C delete.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
