420a rad in 4g63??
FUNWHEELDRIVE
194
Dec 27, 2008
Calgary, AB, Canada
yes i searched. can someone just tell me if there is a difference between the 420a rad and turbo 4g63? will the 420a fit?
thanks
I believe the radiator will bolt up to the rad support just fine, it's just the coolan entry and exit ports that will be different. You would need flexable coolant hoses to make your own lines.
If you have a 420a radiator laying around I say go and see what the line fitement would be. If it's not too twisty and long then it should be fine. Otherwise just get a 4g63 radiator.
Dimensionally the same, upper hose is very close, lower hose is on the driverside. You would be running a radiator hose into the alternator/downpipe area.
