450cc injectors ran by auto ecu (390s)
1bad91tsi
97
Jan 22, 2008
east indiana, Indiana
I know it will flow more fuel(450s where 390s should be) but what cc would it be equilivent to?
Would it flow 450cc?Or would it flow 510?
I know my logic is off but if 60cc difference between the 390 and 450 then a swap to 450 where it thinks its 390 would yeild 510 WTF,
There are a few other threads talking about injectors and such. Yes, you do need an M/T ECU to run the 450s, and you should probably consider getting a new fuel pump, maybe 190lph; Rewire it. You may also want to consider getting an AFPR, in case you want to eventually upgrade to even BIGGER injectors.
Okay I may be wrong on this one but I thought manual or auto ecu made no difference. The engine computers are the same right? You are talking about using turbo injectors (450cc) in place of 390's. Are you trying to use a non turbo ecu in place of a turbo one. I dont think this will work but I could be wrong. Is the car turboed. If it is and you are using 390's right now I would think it would be lacking fuel real bad. Just my .02
I have ran 450's in my auto car with the factory ecu.It runs the same as if it had the 390's in it.
I'm still waiting for the OP to respond but I'll remind the rest that on a 1G manual car the stock injectors deliver about 411cc/min of fuel because of the lower base fuel pressure (36.3 psi). The ECU knows this just like the automatic ECU knows that it's using 390cc injectors at 42.7 psi base so that the effective size is SQRT (42.7/43.5) * 390 = 386.4cc/min
so i just bought a 90 m/t ecu.I am going to swap the wires but should i leave the auto fpr or get a manual one?I have a safc and have some decent upgrades(typical 350 hp,b16g fmic,660s,so on)
I dont want to get a afpr if i can just use the one i have.
i ran the 450 cc injectors in my auto without a single problem, i was actually able to run a psi or 2 more without knock on the stock auto ecu i might add
