420A 420a turbo build parts list?
420a_zhen
Feb 19, 2023
joplin, Missouri
Ok so I have a 95 gs 2g 420a that I wanna build
And I need a parts list, I have all the turbo parts I just needa link or something like for rods, pistons, cams, springs, bearings, etc
EAGLE RODS
JE PISTONS (you will need to verify the proper bore size. 8.8:1 compression is recommended for boost on pump gas)
CROWER CAMSHAFTS (I recommend the stage 2.)
Bearing choice is up to you. Just make sure you measure the crank to check if it's within spec. Some people seem to prefer King bearings but I have always used Clevite and never had problems.
Brian Crower makes a good titanium spring/retainer kit. They are advertised for Neons only but the Eclipse parts are exactly the same. See them HERE
EAGLE RODS
does that mean i can use neon cams in my motor? if i wanted to
any tips for building this
No, Neon cams are not compatible. Technically you can modify them to work but why do that when 420a cams are available.
bc eclipse cams take forever to ship vs where neon cams would come in with the rest of my parts, unless i can find eclipse cams that can get to me by the first or close to then
If you use the link that I posted above, I don't see any reason why it should take multiple weeks to receive them. I ordered my camshafts from that specific website and they arrived around 5 days after ordering them.
We don't have the quantity you requested, we'll back order the remaining 1. The average days to make for remaining quantity is 28 is what it says for me
