420A 420a pistons
fast gs said:
cams and cam gears
2gnt says 20hp max for cams and 5 or 8 i forget for cam gears. but thats if you have all the previous stuff done. but we look down upon bench dynoing and "how much power from this" questions.
Expect 1whp from a set of Crower 2s on an otherwise stock 420a, and I'm pretty sure you won't be let down. Just like any other internal modifications, cams will produce the most power when used as a part of a comprehensive engine build. An intake will give you more horsepower when you have the intake and TB ported, a massaged head with cams and adjustability, and a complete exhaust system of the proper ID than it will by itself. Remember, build the shit out of a 420a without any power adders and you're still going to be under 200hp. Food for thought...
so if the rods are forged, then all you really need to replace are your pistons right??
