420a injectors help
pureinsanity
Feb 8, 2011
bellvernion, Pennsylvania
Quick question I’m looking for some 1200cc injectors for my 420a. I just ordered my megasquirt and I started looking for injectors. I can only find low impedance ones. I would rather use high impedance ones and not have to worry about using resistor packs. So does anyone know any high impedance injectors that will work on a 420a without boring out the intake? But if I do go with lows what would be the best way of doing it? One last thing has anyone ever use or herd of TRE injectors? ( Tre 1200cc MIN Fuel Injectors Fit Bosch E30 s14 M10 Turbo DOHC 420A 114lb HR 4 | eBay ) thanks!
Ok, well how about the rest of your setup, like are you going to be building your bottom end (high or low comp.) and what are your power goals (ex. 350hp or 450hp), and are you going to be running pump or e85?
Ohh sorry. I got a built bottom end with forged rods and pistons. 8:1 compresion. I would be happy with 400 hp with the possibility of being able to get to 500hp. Probobly sticking with pump gas
well if I got cams I defininlty would get stronger valves and lifters. Also I got a full 3 inch exhaust. But not my daly driver more just of a fun car so i'd like to get some agressive cams! :D
