3rd gear is randomly notchy unless...
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
....I hit soak the cables at the tranny housing with deep creep or PB blaster. This stops the notchiness for a few weeks. It is not a grind or anything. It just feels ever so slightly notchy going in...different from the other gears. I have tried every tranny fluid mix but nothing fixes it. This all started after I blew up my PTT clutch and replaced it with and XTD Stage 3 setup. I replaced the bushings with aluminum ones and have adjusted the shifter cable a million times.
No big deal really...just wanted to know.
Thanks
One thing I would test is putting the rubber bushings back in and see if the issue goes away. There is a chance that the issue has always been there but it was masked by the soft bushings and now that everything is solid you can feel it.
Thanks but it acted like that with the soft bushings too. :(
