2G's, post your pocketlogger logs!!
Here's my log at around 15psi
RPM Timing Airflow TPS O2
3900.0 4.0 17.2 92.34 0.88
4236.0 9.0 17.79 96.27 0.88
4552.0 9.0 19.35 96.66 0.88
4884.0 9.0 21.23 96.66 0.9
5196.0 11.0 22.07 96.66 0.9
5484.0 14.0 22.65 96.66 0.9
5764.0 16.0 23.13 96.66 0.9
6028.0 17.0 23.49 96.66 0.9
6272.0 20.0 23.64 97.05 0.9
6496.0 21.0 23.7 97.05 0.9
6712.0 22.0 23.85 97.05 0.9
6904.0 21.0 24.06 96.66 0.9
7084.0 22.0 24.07 97.05 0.9
7256.0 23.0 24.04 96.66 0.88
7272.0 23.0 23.88 96.27 0.88
Here is mine. open to any sugustions;
im not an expert but it looks like your timing is getting pulled at 6904 rpms, meaning you are getting a little knock, try richening it up a little and see what that does.
my bad i didnt realize that you were just posting your log, for some reason i thought that you were asking for advice, sorry
1st log ever.
A/T, 2nd-3rd gear pull.
S-AFC is -5% for low throttle(all rpm), -6% to -8% hi throttle(low-hi rpm)
Don't ask, i just leaned it out a bit is all :)
Good? Bad? Ugly?
On pump gas, my o2 is generally a fair indication of lean or rich conditions. My ecu usually likes to see the o2 voltage around .96-.98v on 91 pump and .94v on 100 octane. These ranges consistently yield the best timing curves. However, on leaded gas I don't even bother to look at the o2.
