2g with gas in the intake manifold
GSX n QUEST
Jan 29, 2008
Reading, Pennsylvania
i need some help, i blow the head gasket and i touk it all apart n pull the head off and then i tip the head and alot gas pourd out the TB??? WTF i never seen this befor, the motor n head is fully rebilt n all new gaskets.
did you check in the cylinders to see if you're running super rich?? I've never heard of this happening either....im sure you're not imcompetant but maybe its coolant and not gas??
If the diapragm in your fuel pressure regulator were torn, it would allow engine vaccum to draw fuel into the manifold via the vaccum hose.
It's either that, or a leaky injector, or it was leaking from a disconnected fuel line on the rail, or it wasn't fuel.
  • Wanted 6 bolt NT water pipe
    • chrisman287
