2G Wheel Bearing fun need help ASAP
cait sith
2,037
15
Nov 22, 2002
Brooklyn, New York
Alright, I've been disassembling my 2G's rear wheel assembly to get access to the wheel bearing and have come to a noteable problem.
I cannot get the wheel bearing off. I've sat with a puller and it just doesn't want to move even with over 200 lbs of pressure on it. I've unbolted everything suspension wise per manual, took out the rear axle from the diff, and still nothing. Nothing at all.
Secondly, is the actual rear hub assembly a press-fit (You know, how the part with the studs and their fitment into the wheel)? The five pages of search information have brought nothing.
I need my car for monday morning so help is needed like, yesterday. :[
So wait...
I've got my new bearing/hub assembly (just a hub assembly) and it DOES NOT have the wheel stud assembly on it. Did I get the wrong part? It would fit up perfectly other than the wheel stud part.
God dammit, that's what I get for going aftermarket.
Well, I guess I'll be returning this little fellow. Should be a much easier job now, at least... :[
Thanks all the help.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
