2g Spyder Electrical Shenanigans.... Wisemen please look!
97gst_spyder
2,262
16
Sep 1, 2008
Lakeland, Florida
So I had an issue after finally getting the car running after it was on jackstands for about 4-5months... Where the windows, top, locks, interior lights, and buzzer all stopped working. Also, after trouble shooting I found out that if a door was open and I turned the headlights on, then back off. The headlights and only the headlights would stay on until the door was closed.
So, I pulled everything apart in the fuse box area and found corrosion issues in the fusebox itself and the ECU thats attached to it (controls everything that is not working). Also, found ~10 random wires that were spliced with tape, nothing else! The wire leads off those 10 splices were just hanging there randomly touching bare metal...
Since about 5 today until now I have been working on this issue again. I installed the new fusebox and ECU attached to it, also fixed all the spliced wires.
SAME ####ING ISSUE!
So at this point, has anyone seen anything like this?
Is anyone selling a FULL 2g gst harness? (dash, engine, interior harnesses)
How is the easiest way to remove the entire harness? (I get the gist of it, but any hints?)
I'm done with ####ing idiots that take a car thats working fine and start cutting shit and ghetto rigging everything. If I ever find this person that owned/worked on this car, I will be the last one to talk to him....
So basically any help at this point would be bamf....
So after all that. I had a few drinks and stared at the car for awhile and messed with the harnesses. Then out of nowhere it started working...
  • Wanted 6 bolt NT water pipe
    • chrisman287
