2g reverse light switch?
Jeff420a_DSM
53
Jan 30, 2014
Chesapeake, Virginia
I have seen other threads on this subject so, I apologize in advance.
anyway, I have a 96 eclipse rs and my reverse lights do not work. The fuses and bulbs are all okay. I think I found the reverse light switch but I wanted to have the community confirm if it is or is not the reverse light switch.
Here is a photo I took:
This is located under the battery tray just so you have an idea of where in the engine bay I took the picture.
Did you check the fuses? 20 16 19. From what it looks like, switch is on end of the trans I cant seem to attach photos sorry
The only fuse I checked was the 10a back up light on the multi-purpose fuse box, under the dash on the driver's side.
