2g NO BRAKE LIGHTS!!! NOT THE FUSE OR SWITCH
LiquidGS-T
75
Jul 8, 2004
Allentown, Pennsylvania
found out my brake lights weren't working. checked the switch, plugged in, checked the fuse... blown. Put a new fuse in, blew immediately. disconnected brake switch and took out 3rd brake light bulb, popped another fuse, right away.
reading the schematic for the brakes, don't really understand. AND i can't find the fuse for the cruise control system.
any body got any ideas on whats shorted?
Do you have an aftermarket stereo installed? I had a wire i believe it was orange that was grounding out and blowing the fuse. It will take out your guage cluster lights also. It took me a few days to figure it out, its the wire for the factory dimmer on the radio that is not used on most stereos.
mind were doing this took....... take all the bulbs out look at the buttom of them "were the 2 metal pieces are" Make sure there isn't any corrorsion on there. If there is just get a wire brush and brush away...
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale EVO 9 Blow Off Valve
    EVO 9 blow off valve $60.00 In good condition, came off 1995 Eagle Talon Tsi. Comes with factory...
    • jmt2028
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
    • jmt2028
