2g mas
You probably won't find much on the 2G MAS. The 1G MAS is regularly hacked, but that is due to it's lower flow characteristics in comparison to it's 2G counterpart. If you find you are over-running your 2G, you might want to look into a GM MAF and Translator. Otherwise you can sometimes fool the ECU by using DSMLink or an AFC.
there is a how to on RRE's website
2gs have an adjustment screw though so you don't really need to "hack" it.
How excatly does the adjusteble screw on the 2g works i seen it. Now im detemrman to find out how they work plz.
That's right, I forgot completely about that screw. DSM-T27, as Attack Eagle mentioned, just take a look at the how-to on RRE's site and it will tell you everything you need to know. RRE Link
