2g mas with honeycombs removed...
Four62ci
Apr 5, 2005
Clearfield, Utah
This may be a stupid question but since I'm a newbie I don't know. If the honeycombs in a 2g mas were removed, is the mas garbage or can it still be used in conjunction with a SAFC?
If all the honeycombs are gone ...yes it is garbage. If you have the bottom and sides gone you can still use it, you will just have really compensate for it with the AFC settings. A hacked MAF is a lean MAF so you will have to richen up your settings a lot.
