2g head on 6 bolt block
1970eclipse
Dec 15, 2011
sunset, South Carolina
I'm putting a 2g head on a 1 g block what size does the head need to be drilled out to fit the block and what else is needed to make this work????
Dont forget you will need a 2g water pipe with the 2g head on the 6bolt block.
Not necessarily.
Although the 2G thermostat housing can only be used on a 2G head, the 1G thermostat housing can be used on both the 1G and 2G head. You use the water pipe that matches the thermostat housing.
alright so i have a 1g block and im looking to get a 2g head because it was cheaper to get one off craigslist then to get valves done....sooo if i get the 2g head im going to have to drill out the bolt holes 1mm and i can use my thermostat housing and i can use the water pipe for mine?? if so then this is just drill the holes and bolt on and im good?
Just drill the head bolt holes with a 1/2 drill bit. Make sure to clean all the shaving out of the head.
alright so do that and i can put it in using the head bolts i took out and everything will hook up...sorry im new to dsm's just bought it dont have enough money to miss understand what your sayin and have to do it twice
