2G guru's NEEDED!
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
Got most of everything installed and got ready to start it, I turned the key and absolutely nothing...except the extremely loud whine coming from the 255.
Turns out there is this black plug on the starter harness that isn't plugged up.....Only problem is...we cant figure out where it goes.
We took the little black clip that goes on the starter off, and rigged up a hot wire to touch to the battery for crank over sakes, but we cant figure out where that black plug goes..Can someone tell us where it should go?
Also this plug comes off from the fuse box, we cannot figure out where it goes either.
The plug off the fuse box is the cruise control, I believe.
As for the other one, It looks to the the neutral switch...I dont know exactly what its called, but look for another plug coming out of the same harness as the o2 sensor, with only one wire. Those two plugs connect together.
I had the same problem, went to start, nothing, then connected that first connector and it was fine.
