TheLunarEc1ipse
- 3
- Sep 23, 2022
Burton,
Ohio
Hey Y'all!
I have been having this really odd sputtering issue for quite a while now, and have tried a few things to try and fix it with no luck.
The car has a really weird sputter in between 2k-4k rpms, higher or lower it goes away. On top of that the car seems to completely shut off while stationary, and even while moving. From start up the sputtering doesn't usually happen, but after the car has shut off 2 to 3 times, it then starts to sputter. The sputtering is most evident in 4th and 5th gear, but can be observed in 2nd and 3rd, although not that as violent. At times, while being inconsistent, the idle likes to hang at around 1.5k rpms, until I add a blip of throttle, and then it falls down to the 800-1k zone.
I have replaced coils, the coil pack, fuel filter, and the fuel pump, and really have had no luck. After every part replacement the car seemed to be fine, until around 30 minutes of the test drive. I don't think it has anything to do with fuel because of the sputtering being within a certain part of the powerband rather than the whole powerband, but I could be wrong. My best guess is that it has something to do with the ECU, but I'm really not sure.
Any help would be greatly appreciated!
