Resolved 2G Coolant hose part number from water pipe to oil cooler
pressf1forhelp
5+ Year Contributor
32
3
Nov 24, 2017
Oceanside, California
I've looked very hard at diagrams and have not found this hose nor its routing areas. Here's a picture of the hose and it's top connection and bottom (kind of hard to see). I'd prefer a part number rather than trying to mix and match at the part store since they don't have much for hoses at least. Most of the hoses I've done were all special ordered from them. I've tried for hours to try to find a way to not get kinks in the lines with coolant hosing I bought and tried the whole "cut and make it work" method. This little hose just seems way too specific for it to work. Thanks in advance!
Solution
MD309661 should be the hose in question. I've gotten away with cutting my own but it really is a tight fit and you need a more flexible yet sturdy hose to do the job.
Which one of these do you mean?
I'm doing all the coolant hoses on both of my 2G 4G63T's. I had one hose leaking & found they were all in bad shape & needing replacing. Most all the OE hoses are discontinued so I bought the G-Plus Silicone Coolant Hose kit (11pcs) from Amazon. Most all the hoses match the OE hoses exactly. The odd balls were the 2 hoses for the upper & lower radiator need the ends trimed to length & they send 2 of the same, long hoses for the heater core & you have to sort of cut one in half to fit the short heater core hose.
These parts catalog pages should help you out as well.
