2g brake swap
turbodsm87
32
Aug 10, 2005
xenia, Ohio
im building my car right now and i have it competley disasembled. i was thinking about doing a brakes swap because i had heard that the 2g brakes were du7al piston. is this true???? if so are they a direct bolt on????? or do i need to change other parts, master cylinder, proprtioning valve, ect.... thanks for the help in advance:thumb:
Here you go. This should be all the information you need.
http://www.vfaq.com/mods/BigBrakesInfo.html
Yes they are a direct bolt on, but you will need to change your brake lines. 2G's have banjo bolts on the brakes, and 1G's have the screw in fittings. You will also need AWD calipers and dual piston pads. Good luck.
