2g 420a fog light mod?
eleclipse99
84
4
Jan 14, 2010
c, Europe
I was browsing to try and find a tutorial about moding the fog lights on a 2G 420a. I couldn't find anything except 2G 4g63 stuff. this is the only 2 links i found for the fog light mod.
2G Fog Lights with Parking Lights
Fog Lights With High Beams For 2nd Gens
i want to do this mod to my 420a, but i don't know if the 4g63 fog light mod is the same instructions for the 420a, does anybody done this mod on a 420a? can somebody help me get this done?
My old 420A was just wired to power and to a switch mounted under the steering column on the kick panel. Simple, yet effective.
Simple, There are a few threads on 2GNT.com. That I have come across and show a HOW-TO on it....
Start searching.....
That write up on 2gnt is great, I'm gong to be doing this mod soon sourcing my parts from a spyder( note: with spyders they only have on/off switch for fog lights without power mirrors, it's a plus if you perfer manual mirrors over power).
Its missing wiring them up, other than that seems good.
Anyone know how to wiring them up in a rs or esi and what items needed.
My RS didn't come with fog lights. I wired them together and ran the (-) to a ground, (+) to a relay switch. Completed the relay switch by grounding it, ran a wire to the fuse that goes to my side markers, then a wire from the relay switch to the battery. This way you won't blow any fuses you tie into because the 12v wire going from the relay switch to the battery.
Hope this helps, wasn't sure exactly if you had factory fogs or adding them like me.
