91orangeGST
- 193
- 1
- May 25, 2004
Winfield,
Missouri
Like the title says I'm building my 1991 GSX to reach a goal of around 25 psi of boost and high 300 hp or low 400 hp. I'm posting a parts list and I would like people to post suggestions or parts that would support my cars demand.
ENGINE:
Wiseco pistons w/ rings 20 OVER.. End gap .004 in extra on #1 and .007 in. extra on #2 ring
Clevitte 77 rod and main bearings
ARP EVERYTHING (main, rod, head)
Cometic Hp head gasket
Bronze valve guides...... Do they require 1mm bigger valves???
T3 or T4 50trim - Stage 3 - .63A/R
ACT 2600 clutch
Findez*** aluminum flywheel
3" turbo back exhaust
FMIC 28" by 12" (Should I go bigger???)
New intake tube and K&N filter W/ air sensore box removed
3" Dejon tool upper intercooler blow thru
GM MAFT with the tuner (Will this be good enough to control the fuel and air supply or will I need a dsmlink?)
walbro 255 fuel pump
AFPR W adapter and stainless lines.
750cc injectors ( will I need bigger ????)
All gauges...
Turbo XS RFL Vented bov
Manual boost controller...
Please reply with any ADVICE or suggestions or anything that will help me before I purchase my parts list. I dont want to order a part then have it screw up because its not able to handle the higher demand. Also I am on a budget so anything cheaper will help alot!!! Please help with any advice!
Thanks,
Kyle
ENGINE:
ACT 2600 clutch
All gauges...
Thanks,
Kyle
