22 psi mistake
mystiquesvt
Jan 14, 2005
colorado springs, Colorado
So, the guy that I had purchased my 90 gst from had been diving the car @ 22psi for a month on stock everything!!! As soon as i got the car I set it @ 12psi and a week later the turbo craped out. sense then, I have replaced the turbo, the cracked manifold, got new o2 housing while i was at it, the fuel pump, and all supporting gaskets and bolts.
the engine was rebuilt 50,000 miles ago. Is there anything else that I should expect to be replacing soon, or that I should replace just in case?
thanks
22 psi and no fuel cut? strange..
do a compression test, (and a leak down test accordingly) and check your base timing out..
depending on ur results go from there.. :thumb:
mysticsvt - I don't think you are allowed to have the same/similar posts in 2 different places... one in Engine Performance and one in Problem Diagnosis. ;)
yah, i didn't figure out that the problem diagnosis place was here untill it was too late.
  • Wanted 6 bolt NT water pipe
    • chrisman287
