2 questions
Dvcaptainm
Nov 5, 2011
Newbury Park, California
I have spent the better part of the afternoon searching to no avail not sure if I was using the right terms, I have two questions,
First can you use the t25 coolant banjo bolts on a 16g or do i need to purchase new ones?
Second I had found a guide on the forums but forgot to save, but does anyone happen to have it saved? I need a guide on removing the oilpan, my local shops dont have the manual for a 2g talon or eclipse in stock.
So here goes: posts = #3, #11, #16 are important.
1. Drain oil (duh)
2. Remove down pipe
3. Remove t-case (5 x 17mm bolts)
4. Unbolt driver side axle (2 x 14mm bolts)
5. Remove scatter shield (next to the clutch)(2 x 1mm + 1 x 12mm bolts)
6. Remove turbo oil return
7. Unbolt pan (18 or 19 x 10mm bolts) and drop (it will snag on the driver side axle, you'll have to push the axle back towards the rear of the car)
Install in reverse order.
Good luck.
http://www.dsmtuners.com/forums/newbie-forum/376761-how-replace-oil-pan.html
