2 nipples on Tial Wastegate???
4g63telantra
454
Dec 10, 2004
Toronto,
I have a 38mm Tial wastegate and Ill be running a MBC with the set-up.
I need to know is, on my tial WG, I have 2 nipples, 1 on top and other on side.
So would I have to run 2 vacuum hoses of the WG or just 1 when a MBC is being used and what nipple? (top or side)
Would I leave the extra nipple on the WG unplugged or plugged?
Dont do anything with the top nipple on the wastegate, Run a line from the side nipple to the MBC, and you'll run a line T'ed off your BOV line to the other side of your MBC.
It also depends on what type of MBC you have. Ball and Spring, and Bleed Types MBC's have diffrent line configurations you can use. Do a quick search around to see what configuration you need.
Good Luck :thumb:
