2 cylinders won't fire. PLEASE HELP!!!
odormat000
147
Mar 5, 2008
Vancouver, Washington
so my when i start my car only cylinders 3 and 4 fire causing it to be completely undriveable. i checked compression and all seemed to be good. i checked for spark and all cylinders had the same spark. then i listened to my injectors and they were all clicking. does anyone know what the problem is? could it have to do with my ECU? Please help me. THANKS
have u recently done any kind of work to your car as far as engine mods(ignition mods)? possble maybe spark plug wires crossed, make sure they're 4-1-2-3. Unless u have link with a '95 eprom, and your CAS should be inverted in link too and your plug wires should be 3-2-1-4. You say u have spark? which way did youcheck for it? You could checkthe pin-out voltage off your ECU that goes to those injectors. Oh and by the way what kind of car is it?
it's a 1991 Plymouth Laser RS and I bought too plugs and wires to see if that was the problem and it didn't fix it. i'm positive the wires are on the right spot. to check for spark i pulled the plugs out of the head and turned over the engine and the spark jumped about an inch. i haven't done anything in ways of ignition mods either. i also checked all the injectors and they were 3 ohms each. which part of my ecu do i need to check?
Please don't take any offense, but how do you know specifically that 3 and 4 fired and not 1 and 2?
i can let me car run for a few minutes and touch my exhaust manifold on cylinders 1 and 2 (which are closest to the driver side) and it's not even warm. when i can't even try to touch cylinders 3 and 4 on my manifold. and i checked compression and they were all the same. not to mention they're not going to go out at the same time are they?
if the gasket between the cylinders blew they would
if 4 and 3 are firing then so should 1 and 2 due to 4 and 1 being the same coil pack and 2 and 3 being the same
yeah that's what i was thinking
i called a shop who does only dsm's and they said they had a guy bring a car in with the same problem and it turned out to be the CAS. Also he said maybe my ECU has a leaker in it causing stuff to go wrong. i'll have to check it out. It would be a good excuse to go EPROM haha
Crank it over and pull the plugs out of the two dead cyls, see if there is any fuel actually getting to those cylinders.
Another way of doing it would be by putting a noid light on those injector connector and see if they flash.
ok people so i am at a true stump on fixing my car. i have done almost every test there is and still can't figure out what's wrong with my car. cylinders 1 and 2 won't fire. all cylinders have good compression. plugs have spark. pulled off CAS and then spun it and all injectors fired. all injectors have 3 ohms. pulled out my ecu to check for a leaker and it looks perfect. Does anyone know of a way to test my ECU when it's out of my car to make sure it's not one of the problems? does anyone know of any other tests i should do to see how to fix this piece of crap on the side of my house? PLEASE HELP ME!!!!
Seriously, I would do what others have said in this thread....check that power transistor. I had the same thing happen in the Laser.
