1st log in this section, good or bad
bluetlr2001
510
6
Mar 6, 2006
Louisville, Tennessee
Heres my log i ran the other day with my afc -20 across the board at hi throttle.
Rpm Timing o2
2944 31 .860
3052 9 .900
3460 2 .920
3972 6 .940
4500 7 .980
4952 9 1.000
5272 10 1.000
5588 11 1.000
5852 13 1.000
6092 15 1.000
6312 16 .940
This is with stock injectors also.
Im only running 15psi on stock t-25 though. Ive done a boost leak test and fixed most of them before i done this log. The only leak i can find now that ive not fixed is my pcv. Im not sure if it will make it run that rich or not. Ive replaced my injectors with what were suspossed to be stock but im not for certain if they were or not. They came out of a stock 97 gst like mine, the guy blew his motor and got another one.
Ive tried running the afc at zero and i run to rich and my timing gets down in the negatives when i go full throttle at low rpms. Ive tested for for boost leaks and have none. But the injectors ive got in my car were used so im not certian if there stock or not, the car they came out of was stock so i think they are.
