1ga sideskirt question
wcpierson
296
Sep 16, 2005
Cedar Knolls, New Jersey
i have a 91 laser and i was wondering if the sideskirts from a 1ga eclipse or talon will just bolt onto my car...thanks
You will need to drill holes for the push tabs, there are only two actual bolts and the rest is push tabs and double stick tape. The body lines are the same though so they will fit.
The 1ga Talon side skirts are a little bit "beefier" than the Eclipse ones. The door caps are attached by double-sided tape, and the actual skirt part (besides tabs on the bottom and holes for bolts at the ends) are attached by double-sided tape and tabs similar to the ones holding your plastic interior parts. I pulled the 1ga Talon side skirts off of a car in a junkyard and they have place holders for plastic tabs that snap into holes on the body.
