1g to 2gfwd swap flywheels diff from awd?
custom man
Aug 12, 2004
duluth, Minnesota
I have the conversion list from magnus and wire diagram. I'm just not sure if I have to change coil packs. I have flywheels from both and appear to be same. Any suggestions welcome. very familiar with 2g just not 1g. :confused:
I don't remember the exact measurements, but the awd flywheels are smaller than the fwd. I also am pretty sure that 1g and 2g flywheels AREN'T the same .. so chances are you'll need a new one either way. Actually a friend of mine swapped a 6 bolt into a 1995 tsi and bought a stock 1g flywheel to do the swap.
This is directly from Road // Race's site:
AWD flywheels have a smaller outer diameter and smaller diameter ring gear. 1G AWD flywheels have an additional weight ring cast into the back side to increase the weight.
FWD flywheels with their larger diameters have less material on the back side. You can see the step down on the outer diameter
thanks guys now as far as clutch set-ups i was told my 2g will work but i do have the 1g with it just want to make sure. cannot find a website that specifies it. Need to order one tom. any suggestions ACT cluctchmaster exedy ect.
clutch doesn't matter as far as 1g or 2g. I run act 2600 and I'm happy with it.
appreciate the quick help sure I will more ?'s later on. any other suggestions or things to look for with my swap would be great. :cool:
