ereckerdeet
- 60
- 2
- Feb 3, 2005
Lebanon,
Indiana
I'm rebuilding my engine, decided might as well do it right while i'm at it
If anyone sees anything I've missed/don't need/knows a better part/knows where to get said part cheaper, plz holler!! Thanks
Stage 1: solid bottom end
clean block/bore to 87mm, plateau hone, re-tap mains/head bolt $LABOR?
pistons+rings ROSS
~8.8-1 compression, 87mm for use with stroker 4g63
rods+connectors CROWER
~8.8-1 compression
planning on getting these as a set from Magnus, not sure on price yet
magnus
905 264 1989
crankshaft+bearings
4g64 6 bolt
http://www.rpmmachine.com/
13930 $125.00core $149.62price
caps align-honed....$LABOR?
ARP main studs/head studs
$190
machv.com
Concept racing main bearing cap alignment dowel kit
$49
machv.com
balance shaft removal
$44
machv.com
Cometic 87mm head gasket
c4235-051
$83.95
head porting... $LABOR??
valve retainers/springs...
Crower stainless steel swirl polished valves, +1mm
$271.26
machv.com
Will these valves work with fp2/3/4??
misc gaskets...$200
Cams...think the fp3/4 are worth waiting for, or drop 272's in...? $~400-500
intake manifold...whatever's the best bang for the buck, looking to flow ~750-1000+ horse eventually. Looks like this is gonna cost roughly 2500... recommendations welcome
~Eric
pistons+rings ROSS
~8.8-1 compression
magnus
905 264 1989
crankshaft+bearings
4g64 6 bolt
$190
machv.com
$49
machv.com
$44
machv.com
c4235-051
$83.95
$271.26
machv.com
misc gaskets...$200
~Eric
