1g Speaker Wire Colors??? Help!
n0va91TSI
267
Mar 2, 2004
Honolulu, Hawaii
My car came with a total POS chiltons book that explains nothing at all.
Trust me I looked. Doesnt even tell wire colors.
I just ordered a harness for my 91 talon so I can use my pioneer headunit.
I need to find out what wires are what so I can set up the haness.
Anybody know what the wires are or even a site that shows with pictures or somthing
HELP!
This is so redicules! I know a million ppl have put in aftermarket headunits. And After scouring the web for 2 hours not one site talking about sound systems in a DSM (except for speaker mounting) I cant believe that the whole dsm community is only concerned with HP.
Anybody know of a site that explains what wires are what in the factory harness????????????????????????????????????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
anyone? Please
Found this on DSMTalk:
1990-93 DSM Wiring Information (Eclipse and Talons should match)
Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach White/Black Multi Coil Pack
Brake Switch Green Brake Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Green/White White Conn Rear of Fuse Panel
Head Lamp Red (-) Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Tan (-) Inside Driver's Door,Dark Blue all other Doors
Door Lock Brown/Blue (-) Driver's Kick at Door Lock Relays
Door Unlock Brown/White (-)
Horn Wire Green/Black (-) Steering Column, use Relay
Cruise Information
Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/White Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Green Brake Switch
VSS Lead Yellow/White Passenger's Console Largest Connector on ECM
Pulses Per Mile 4000 PPM
Stereo Information
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground Chassis
Illumination Green/White
Dimmer Black/Yellow
Antenna Trigger White/Black
Antenna Left Rear
Front Speakers 4" Dash
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Rear Speakers 6 1/2" Side Panels
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
