Resolved 1G Single Green Wire connector
Nors
110
Feb 15, 2007
Delaware County, Pennsylvania
Okay, so I have been searching and the answer usually comes up idle switch. But is there any other single green wire connectors? I have a pic if anyone needs a reference. The harness is just hanging with the engine gone so its hard to tell where it goes.
Answer to what question? And yes, pics will be beneficial.
Haha, sorry I was in a rush when I typed that.
I found a single green wire connector and it was pretty screwed up holding on by 1 strand of wire and it was a single green wire. I ripped it off and plan on soldering a new one on, just wasn't sure what it connected too.
Green wire is on the left and its in the same harness as the connector on the right (thought that may help).
The wire connects to the IPS and tells the computer your throttle body plate is closed.
Attaches to the Idle Position Switch on the top of TB on firewall side.
there should be a male plug on the top (firewallside) of the TB. it slides right in. the plug is above where the other large plug goes (IAC).
