dadsgsx
- 45
- 1
- Apr 22, 2009
wilmington,
Delaware
.I own a 97 spyder that is in a overhaul process
Its not a DD car and now where even close. This is rwd conversion. Having a issue as far as the rear goes. From what I have read certain year explorers have the same length 31 spline axles as a 1 g gsx. So that said problem solved. But from what I read 1g rear s wont go into 2gs just want to know y. Even if replace everything? Subframe, suspension etc??
.. I want to take a 98 eclipse gst spyder and make it a awd.. now i know this is a task not lightly taken. I am already having a roll bar welded in to support the body flex and im already doing cross member tubing along the uni-body to accommodate airbags so that will strengthen the body. but now it comes to the irs since it is going to be a complete fab anyways i was wondering if the 8.8 gto irs setup would be a good way to go??
