1G radio wiring diagram help
wcain143
Nov 1, 2005
indianapolis, Indiana
I just bought a 94 eclipse gs that had an aftermarket radio in it. 2 days ago, someone broke in and stole the radio and cut the wires before the harness so now all I have is a jumble of wires. I pulled a vfaq on a gen 1 but am still a little stumped on some of the wires. I have all the speaker wires separated now and only have a white/black wire which I am assuming is the power antenna, a green/white wire that is possibly the + illumination wire, a black/yellow wire that is possibly the ignition switch + (possibly all time hot), a blue wire that is ACC, and a mysterious red/black wire. I have no idea where the negative wire is. Any help would be absolutely appreciated. Also they took the housing around the radio I can't remember if it was a part of the original car of if it was part of the aftermarket radio plastic.
Thanks.
Radio 12v red/black +
Radio Ground (chassis) (aka there is no ground wire make your own)
Radio Ignition blue +
Radio Illumination green/white +
Factory Amp Turn-on N/A
Power Antenna white/black +
LF Speaker +/- white/blue - black/blue +,-
RF Speaker +/- white/red - black/red +,-
LR Speaker +/- yellow/blue - gray/blue +,-
RR Speaker +/- yellow/red - gray/red +,-
Usally when someone cuts the wires they pop the fuses so be sure to check them
and this is for a 1g eclipse only.
Thanks for your help! hopefully will have a radio in this evening!
