1G power steering in a 2G
justinh722
131
May 3, 2010
Hampton, Iowa
I have a bad 2G power steering pump and I'm doing a 6 bolt swap that came with the 1g pump. I was curious if it's at all possible to swap pulleys on the pumps? I tried searching but couldn't find a whole lot on the subject.
Nobody have the answer? I searched all night.
Can you clarify what you are asking?
Are you asking if the pulleys are interchangeable or if the pumps are interchangeable?
Basically, I'm asking if the 1g pump will work at all on a 2g. I know it runs a V-belt but is there a way I can just put the V-belt pulley on the water pump or is it even at all possible to change pulleys between the 2?
The pump itself is almost the same, but from the images I found online it does not look like the pulleys can be swapped.
I am going to have to say no based on this...
1G:
2G:
