GSLENK
- 1,416
- 54
- May 25, 2011
DC,
Maryland
All the good stuff seems to be gone. Last call $150 takes everything remaining.
Ebay links to stuff/groups that are all packaged up and ready to ship. Shipping is included in these listings. Might be flexible on price if picked up or bought outside of ebay.
Or make an offer to pick everything up. I'll most likely say yes to almost anything. Want it all gone!
DSM parts:
“Popular” stuff: (take it all $150)
Cylinder head, 2 bent valves w/cams, gears, springs etc… ($80)
Coil over spanner wrench set (2x big, 1x small) ($10)
Subframe bushings not sure if rear or front set, includes sway bar bushings. ($20)
OEM metal front bumper (not cut, very low miles ~30k)
Fusebox engine harness (from fuse box to headlights, AC etc…) ($30)
Misc new OEM: (take it all $20)
Slave/clutch rod measures 3.5” long tip to tip (not sure if regular or extended) ($10)
Rear toe eccentric bolt kit 2 pairs ($33):
2x MB515167 - Bolt
2x MB303958 - Nut
2x MB111440 - Eccentric Plate
2x MS450045 - Lock Washer
Ignition ($10):
Spark plugs
5x NGK BR8EIX 5044
4x NGK BPR7ES 5534
Misc: (take it all $50)
ACT clutch alignment tool AT20
“Hayame” aluminum spark plug cover
OEM (used, 30k miles) spark plug cover plastic
2x power transistors (for ignition, used unknown condition)
OEM Laser 3pc tail lights
2gb Headlights 2 pairs, bulbs etc.
Interior ($10):
Misc panel clips
Twin single DIN radio bezel
Center Vent gauge bezel
Several dome light assemblies
Wiring (stereo): (take it all $70)
5x 150amp MIDI fuses
0/4/8ga fuse junction block
0/4/8ga junction block
0/4/8ga batt terminal
4/8ga batt terminal
0ga grommets
4ga grommets
2x long length RCA amp signal wires
20ga and 14ga silicone copper wire (~10ft each? 4 diff colors)
4ga compression ring terminal
TONs of 0ga ring terminals
17ft 8ga power wire w/ inline fuse
13.5ft 4ga power wire w/ inline fuse
7.5ft 0ga
4ft 0ga
2ft 0ga
3’ 4ga
3.5ft 4ga
13.5ft 12ga twisted speaker wire
Misc 8/4ga scraps (~1ft+ each)
TONs of 18/20 ga amp signal/hookup wire
Silicone/t-bolt/BLT: ($25)
Ebay link
https://www.ebay.com/itm/183909680663
BLT 3-1/4” ID
BLT 3” ID
2-1/4” ID silicone coupler
2-1/2” ID silicone coupler (5” long)
2x HPS all SS T-bolt clamps (78/70mm size, new, fits 2.5” IC pipe/couplers, I think)
DIY AC retrofit parts: ($free-$10)
Misc hose ends/clamps/orings etc.
5ft aeroquip GH 134-6 (part # 0012440) hose
8ft-7”aeroquip GH 134-8 (part # 0040398) hose
Crimp tool
Misc hose/etc: ($free-$10)
6ft clear boost gauge hose
5ft clear boost gauge hose
12ft clear coolant reservoir hose (for 1/4” or 1/8”? barbed fittings?)
23” DEI heat shielded conduit ~1/2” ID, ~3/4” OD
4ft (1.5” across when flat) nylon shrink wrap braided (shrinks 1:2 or 1:3 ratio, I forget, used it to wrap 6an SS/teflon lines, fits over fittings, shrinks snugly)
4ft of ¾” heater hose
1g silicone heater hose kit, missing large radiator hoses, and heater core hoses, has all the little ones IIRC, maybe missing a few clamps.
Misc brass barbed fittings/plugs/npt, they are JIC, not -an)
Spring loaded hose clamp (used for heater core coolant hoses)
Small coolant hoses silicone kit with clamps
Tinkerer’s galore stuff: ($90)
Ebay link:
https://www.ebay.com/itm/183909535104
Omni 4-bar (bad unit) plus a DIY copy in cylinder form, threaded for 1/8 npt
100psi, 150psi oil pressure senders
Tons of relays, pigtails, LED’s, digit displays, electronics components etc.
Arduinos, raspberry pi’s
circuit boards for Arduino gauges
see pics, it’s a ton of goodies
DSM parts:
2x MB515167 - Bolt
2x MB303958 - Nut
Ignition ($10):
Spark plugs
5x NGK BR8EIX 5044
4x NGK BPR7ES 5534
Interior ($10):
Misc panel clips
4/8ga batt terminal
0ga grommets
4ga grommets
7.5ft 0ga
4ft 0ga
2ft 0ga
3’ 4ga
3.5ft 4ga
Ebay link
BLT 3-1/4” ID
BLT 3” ID
Crimp tool
Ebay link:
