1g output shaft retaining ball missing
805eclipse
159
Jul 16, 2003
Newbury Park, California
So i was taking off my transfer case to replace the seals and when i pulled it away from the transmission the output shaft started sliding out with it. i was able just to pull it all the way out. so i took off the transmission end case and removed the vc to see if the ball was there and it is gone. does that mean its inside my transmission somewhere? it was not anywhere inside the end case, is it possible for the ball to end up deeper inside the tranny? Thanks for your help.
