1G 1g i.o.d fuse look like?
Topcarparts
31
Aug 27, 2019
Manila, Asia
I don have radio
Power window switch supply
Ac power supply
So far ive search and looks like the problem is i.o.d. fuse
But when i check the i.o.d fuse in the fuse box its blank.i cant see anything.
So anybody has a sample picture of i.o.d fuse for my 1g eclipse 4g63t 1991
Need help..
Problem
No radio power
No ac power
No power on window switch
I think this is bcoz i.o.d fuse problem.but when i check my fuse box.the i.o.d fuse SL is MISSING no more.. so i dont have any idea what it looks like.. anybody has the picture of this fuse?
Hey, I'll try to help.
First: posting in the early am multiple times prolly won't help you, everyone's sleeping.
Second: creating multiple threads for the same issue is a no-no here, just a friendly reminder before a mod comes in harder on you.
Might want to check the interior fuse box, I don't actually think the i.o.d. is a fuse of any kind, but a check connector. What for, idk.
Your problem is most likely located with and accessory or radio fuse directly, possibly the "room" fuse.
Check them first, make sure they have continuity across the fuse, even if it "looks" good. Then test for voltage on both sides of the fuse with the key in all 3 positions: off, acc. and ign.
Report back with findings.
Im realy sori sir.. im new here..
Tnx much for ur reply.. i will find the room fuse and check...
But yesterday i check the conector of the i.o.d in fuse box.. im surprice there is no wire at all its blank... no connection.. so i hope this room fuse will help me..tnx for suggestion sir
