1G FWD Half Shafts
You should be able to get remanufactured half shafts at your local auto parts store in exchange for your old shafts. Make sure to check the shaft diameter, there have been some reports of replacement shafts being skinnier than stock.
If you need to reply, hurry up and do it before Defiant closes the thread! :)
HELP!!!!!!!!!!!!!!!!
i just replaced my passenger side half shaft and it doesnt work i went to 3 different part stores and they were all the same but it is almost like the shaft that goes into tranny is to small the gears barely grab it and you can spin it by hand and it just clicks doesnt grab at all
Can you put the old one back in temporarily? There is no way to make a small shaft work, so just take it back to the store and ask them for the right part. If possible, take the old shaft with you so the parts guys can take some measurements, if they need to.
