1g Drag Racing Alignment Specs
LocknessMonster
113
Jun 19, 2007
Saint James, New York
Got all the bugs sorted out and am bringing the car to get dyno tuned in the next couple weeks. The car has all new bushings/tie rod ends/ball joints/control arms/coil overs/ rear toe elim etc and I would like some input from the 1g drag guys on what type of specs to tell the alignment guy. This is a track only car not street driven. Thanks for the help in advance.:thumb:
You can only adjust toe unless you have a camber kit. But generally you want as most tire contact you can make so stock spec 0 toe is preferable. More important thing of the suspension is if you can adjust pressure evenly so you can launch effectively and have proper ride height.
