1g changing from a 7bolt to 6bolt need advice...
talonkid93
64
Dec 16, 2007
bayonne, New Jersey
Hello I have a 93 talon tsi awd with a 7bolt motor in it. I want to swap in a 6bolt motor and was wondering if it will be difficult and if theres anything ill need. will the motor mounts i have in there now be good for the 6bolt. Also will i have to change to flywheel since im going to a 6bolt from a 7bolt? if anyone has had some experience here with this same swap on this same car can you please tell me exaclty what i will need to be prepared for since i have never done a motor swap before?
LOL Sorry about that, tried to post too fast. The server was pretty slow there for a few days. Too many damn DSMers!
Yes, the flywheel will need a change. I was meaning the AWD and FWD flywheels are different, but yes the 6 and 7 bolt flywheels are obviously different too.
thank you for the information. It seems like i shouldnt have to much trouble then putting the 6bolt motor in.
If you plan to re-use your stock cylinder head, you will need to have the stud holes enlarged in order to fit it onto the 6-bolt bottom end since the 6-bolt uses slightly larger head studs.
To my knowledge these components are also not transferrable: oil pan, oil filter housing, timing belt cover, and timing belt tensioner. Can't think of anything else right now.
Good luck man.
Good luck man.
Hes looking at putting an ENTIRE 6 bolt into a 1g chassis so none of that is revelant.
well noone really answered my question. I was wondering if anyone can actually gimme a list of what ill need for the swap to work since its a usdm 7bolt motor and trans and im gonna be putting in a jdm 6bolt motor in my 93 talon.
